I came home from work and went right to work again, priming the upper engine cowling, engine cooling air intake rings, main gear leg upper intersection fairings, upper engine cowling oil filler access door and rudder lower fairing.
Upper engine cowling primed
Engine cooling air intake rings and main gear leg upper intersection fairings primed
Upper cowling oil filler access door and rudder lower fairing primed
